Cannot ping/skynet will not work while Firewall is Enabled.
spinfuzer
I am not sure when how long ago this problem has occured, but recently I checked skynet and Internet connectivity failed. So SkyNet will not work, nor will any type of pinging from the Web UI. If I turn off the Router's Firewall on the Advanced Settings --> Firewall --> Enable Firewall --> No, my pinging works again and skynet appears to work fine after that. Obviously, the firewall is more important than skynet so I keep the router firewall enabled.
My internet appears to be working just fine outside of the skynet/router pinging issues.
In the past several months the main change I made was moving to PiHole and setting the Upstream DNS in PiHole to use Unbound Manager on my AX86U.
Skynet perhaps won't help with community supported blocklists. Your router's built-in firewall already blocks all unsolicited connections. Run Unbound on your Pi-hole device instead, no need to run in on the router. You may want to rethink and redo your configuration. The simpler the better.
