Firmware upgrade for WAP4410N-E, anyone able to share some image files ?
gpread
Hoping someone on here can help. I have a WAP4410N-E with a 2.0.4.x firmware version and I'm looking to get hold of the image files for 2.0.6.1, 2.0.7.4 or 2.0.7.8 versions so that I can try to upgrade and resolve some problems.
Cisco ended support in 2019, so as far as I can tell there is no way to get firmware upgrade files officially now (even though I found some direct links they are all broken (just redirected to the end of support notice page)
I have done the usual google search but had no luck, softpedia has some but I believe they are not the versions for the European hardware (with -E suffix) for which the image file names/packages contain "etsi" I believe.
If anyone has one/some and can get in touch so as to be able to share/send it to me that would be much appreciated.
Thanks in advance!
Looked at possibilities for OpenWRT, as they do take in orphans, but they don't support it... (small RAM/flash size, and buggy 802.11n-Draft chipset)
I would email Cisco's support team - they will have firmware for these legacy devices.
2014 called, they'd like their AP's back.
