GeForce NOW QoS setting on fiber?
zany130
Do any of the GeForce QoS settings make sense to enable on fiber connections if you use GeForce? I know QoS is actually detrimental on gigabit connections but what do the GeForce settings do? There is GeForce NOW QoS mode under QoS which you need to enable QoS for, so I'm guessing I don't want that, and
Enable GeForce NOW QoS UPnP control
which doesn't seem to require QoS to be enabled?
Should i use the geforce QoS settings?
@zany130 did you receive an answer to your question? What are you using for QOS?
no i just left it at Enable GeForce NOW QoS UPnP control to yes qos to off
If you are a gamer and your clients have Geoforce Now leave it on. Otherwise turn it off.
UPnP should also be off. Security risk!
