Guest Network not Working on AIMesh Nodes
Mike S
I have the following network:
RT-AC88U Main Router with Merlin 386.7
RT-AC68P AIMesh Node with Merlin 386.7
RT-AC68R AIMesh Node with Merlin 386.7
RT-AC68U AIMesh Node with Merlin 386.7_2
The main router has regular wifi SSIDs configured which work properly thruout the network. In addition, a Guest Network is configured for the 2.4G band in the 1st column.
The guest network works properly when you connect to the main router and to the RT-AC68P AIMesh Node. However, on the other two AIMesh nodes, the guest network is visible, but you can't connect to the guest network.
How can I fix this???
Change the nodes back to Asus firmware. You may have better success.
