Hi
I'm looking for some help to resolve the issue I'm facing.
I have an AC3200 running latest Merlin firmware and a netgear smart switch GS108Tv2.
The switch supports 802.3ad (LACP) so I decided to run 2 network cables from the router physical ports 1 and 2 to the switch ports 7&8 and use bonding which works almost as expected, but....
On the router, besides the main LAN I have vlan85 (192.168.85.0/24) which is using VPN to go outside and it is my guest vlan. To make it short here is my robocfg output:
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 5t
2: vlan2: 0 5
4: vlan4: 4 5t
5: vlan5: 3 5t
85: vlan85: 2 3t 4t 5t
As can be seen from above that vlan is untagged on the router physical port 3 and a client connected to that port works as expected. However I tagged that vlan on the ports used for bonding and tagged on the switch side as well. Now when I connect a client to the switchport that has vlan 85 untagged (access port) the client gets and ip address but there packets can't be sent out from the client, basically no internet access. I've already spent a couple of days on this and can't seem to figure it out. One thing that I've discovered is that if on the router I tag vlan85 only on one of the ports used for bonding then the client connected to the switch on vlan 85 will work. What am I doing wrong? Any suggestions?
1: vlan1: 1 5t
2: vlan2: 0 5
4: vlan4: 4 5t
5: vlan5: 3 5t
