HELP: shh keys do not work on two routers, but do on third.
jbspillman
Got some older ASUS routers here, upgraded to Merlin firmware. This used to work for me, not sure what has changed but now I can't login to the older models with ssh keys. I can still login manually though.
I have rebooted them, re-did the keys that work on the RT-AC68U and applied them to the RT-AC66U's.. Strange issue for me. I guess I could use sshpass, but I'd rather just use keys.
Bash:
bash_prompt:  ssh username@1.1.1.1
ASUSWRT-Merlin RT-AC68U 386.7_2 Sun Jul 24 21:37:07 UTC 2022
username@rt-ac66u-b1:/tmp/home/root# exit
Connection to 1.1.1.1 closed.
bash_prompt:  ssh username@1.1.1.2
username@1.1.1.2's password:
ASUSWRT-Merlin RT-AC66U 380.70-0 Sun Apr  8 18:04:34 UTC 2018
username@rt-ac66u-1:/tmp/home/root# exit
Connection to 1.1.1.2 closed.
bash_prompt:  ssh username@1.1.1.3
username@1.1.1.3's password:
username@rt-ac66u-2:/tmp/home/root# exit
Connection to 1.1.1.3 closed.
What type of key did you generate? RSA, ed25519, etc.?
Obviously the ancient routers didn’t change, but maybe your SSH client on your other machine did, and a newer version deprecated some cipher or similar gotcha.
Use ssh -vv to get more verbose output. Compare the working and non-working output.
I see something different..
this is where it is failing on older router..
debug1: send_pubkey_test: no mutual signature algorithm
The keys were RSA and generated via ssh-keygen -t rsa -b 4096
SOLUTION: I generated a key at probably a weaker strength but now it is accepted on all three routers.
ssh-keygen -t ecdsa
