Hi all,
Apologies if this has been asked before, I wasn't able to find answers. Please point me to relevant thread if so.
My current network looks something like this:
FTTH -> ISP optical switch/router (I have no control over it, it asisgns public IP adress to my router's WAN port) -> (my) router Asus RT-N66 running FreshTomato (wifi disabled, does NAT, static DHCP, ...) -> LAN switch (link agregation for NAS, ...) -> AP (second Asus RT-N66 running FreshTomato) -> wifi clients (PCs, phones, ...).
It has been stable for years, I never had to reboot anything, unless I was doing an update or there was a longer power outage (current uptime of router is ~400 days
). The only thing that has become kind of obsoleted over the years is the wifi bit.
I live in a house, where I'd like to have wifi from basement to attic and both floors in between. Currently there is only one wifi device (AP) located in ground floor and it covers ground floor, first floor and basement. Later two more like OK-ish, while attic is hit and miss, depending on where you stand. Now I would like to install multiple APs around the house, each would be connected to it's own LAN cable running back to my LAN switch. So kind of like a mesh, but with wired backhaul. All devices will have power socket nearby, so POE is not required.
I don't have any experience with multi-AP networks, so I'm completely lost right now.
My wishes are to:
1. have much better wifi signal in house and around
2. client devices roam between APs and use fastest band with best signal (I'm not sure this is even decided on AP end?)
3. separate SSID for main LAN, another one for IOT LAN, and yet another one for guest LAN
4. for all devices to be at least as stable as my current setup (this one should actually be much higher in this list...); I just don't wan't to reboot devices in weekly/monthly basis "just because"
5. no/minimal data leak to vendors/3rd party (no cloud, all local config via web page would be ideal)
I'd like to keep most of my current hardware if possible, only changing/adding wifi APs. If any other part of network has to be replaced, so be it. I'd also like that new devices are in a more budget category (much like Asus RT-N66 was back in the day, at čeast compared to enterprise solutions).
Does anyone know of a device(s) that would fit the bill?
I found a bunch of mesh systems that looked really cool (TP Link Deco for example) but most of them force you into cloud configuration, which I hate will all my heart
If it helps, I'm based in EU and can buy from any EU country.
Any advice/help will be appreciated.
My wishes are to:
