instability after upgrading to 386.1_2
tommy1
I have AC66U_B1 with 68 firmware recently upgraded to 386.1_2, i had warnings with love level of nvram memory so I did reset and installed from scratch, unfortunately the router is unstable since then, i need to restart it every 1-2 days cause it looses access to the internet, i'm not able to ping it,
i have relatively small amount of traffic in LAN, the only non-standard thing is that i'm running two open vpn profiles, some devices connected to one node via UDP, and some to another node with TCP traffic, could it be that causes issues with that new firmware ?
do you thinkg comming to previous firmware could be better or would you recommend sth else to trouble shoot ?
thanks
