Hi Everyone,
Wow, what a great forum. Glad that I found it. I have a questions regarding routing of IP addresses.
I am using a Linksys E1000 router with gateway address lf 192.168.1.1. My questions is this: Do all of the devices connected to this router have to use an IP address of 192.168.1.XXX in order to route out to the WAN? If a device connected to this router has an address of say 192.168.3.xxx will it be able to access the WAN? If not then will adding a static route in the router take care of this or will the address need to change to an address in the range of 192.168.1.xxx.
Thanks in advance,
Regards,
Thanks in advance,
Regards,
