ipv6 configuration; stateless or statefull
edwin0001
On my Asus rog rapture gt-ax11000 with the latest version of Asuswrt-Merlin. My router is in bridge-mode. What is the best way to setup ipv6 I was wondering. At this moment the setup is 'stateless' and I can't seem to figure out if by any chance 'statefull' would be better. So far I haven't found any good advice on this topic besides that 'statefull' is like an dchp server, but what are benefits over 'stateless', or should I better leave things to 'stateless'. Can anyone shine a light on this and give me some advice in this matter? Thanks!
L&LD
Part of the Furniture
Welcome to the forums @edwin0001.
Is your router or your modem in bridge mode?
Normally, the ISP determines the IPv6 state.
L&LD
Then you can't change WAN parameters.
edwin0001
I can change it I think...I've got the option to choose for stateless or statefull. When I opt for statefull an IP range is defined. But therefore my question...what to do?
learning_curve
Obviously I can't comment on any other people's ISP & their operational / process setups, only my own, but FWIW I could alter those IPv6 parameters on my ISP supplied, FTTH router, when I used only that router and... once I changed that to using that specific router only in bridge-mode, I can still change those same IPv6 parameters on my Asus router now, without any problem. I chose stateless, after experimenting with both IPv6 parameters, on both routers & I have left it set at stateless on my Asus router ever since. There are many online now, but this article is a simple enough explanation and might help you to decide which @edwin0001
heysoundude
That article is awesome, wonderful. Now if Netflix could only figure out IPv6...
Also, OP, go get your IPv6 "certification" at https://ipv6.he.net/certification/ and (if the stories of all the servers in that article got your juices flowing) use your account to make DDNS a breeze, maintain/edit your DNS A/AAAA records by claiming your free /48...and maybe become a guru. That should help you have the proverbial penny drop.
And there are some neato resources at
ip.bieringer.net​
edwin0001
Thank you so much for your reply. That the kind of information I was looking for, great! I am going to absorp it and see if I can make up my mind.
edwin0001
ip.bieringer.net​
Thanks! Who knows I might be the new ipv6 guru...for now thanks for all the additional information. Lots to read and think about. :)
heysoundude
HE mails you a Guru t-shirt if you make it that far, supposedly. for me, the first 2-3 levels were fine to accomplish what I needed, and I zipped through them in a couple of hours
