Is there a way to save firewall entries?
Phoenix
As we know it's best to do a factory reset on the router when switching between standard ASUS and Merlin firmwares. The problem is I have many firewall entries entered in the URL fields that block Windows 10 telemetry and some bad sites so it's a tedious task to re-add them all over again
1) Is there a way to save them so I can easily load them after doing a factory reset?
2) Is there a way to enter many entries in one shot? like a batch method?
wow, I'd rather re-enter all my settings manually than to use that utility. It's harder than reinventing the wheel.
Only the first time. Then you can do 20 routers in the time it takes to do one. ;)
Or, backup this way and restore only the pieces you need.
/usr/sbin/nvram show > /jffs/nvram.txt
