Is there any router can handle multiple internet lines from different ISP?
From what I've experience - bonding only works from a single provider, as this is generally layer 2, and the Layer 3 needs to be coupled end to end across the bonds.
With 2-3 wan's - load balancing and failover is a generally a good approach for high availability services - there, CARP has some options in pfSense...
https://doc.pfsense.org/index.php/Configuring_pfSense_Hardware_Redundancy_(CARP)
(uTik has similar options here, as do other Router OS's)
They won't - this is how the internet, and more importantly, even layer 2 works... you'll be fine..
Which goes back to my original statement in this thread - one doesn't really need three connections in the first place - but in an HA environment, two is enough if they're from different sources.
There are ISPs that perform bonding over other ISPs.
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
Honestly, for what your goal is, you actually have the simplest solution--3 routers. If size is an issue, you could probably scale back on the routers (most anything can handle 12Mbps these days) and just set up the existing routers as your APs.
