JFFS custom scripts and configs
porfavorhelp
I want to disable JFFS custom scripts and configs. Do i will have problem with the router? I just wat to disable it
It shouldn't be a problem. But none of us can say for sure because we don't know anything about your router or how it's configured.
What router? What firmware? What scripts and custom configs did you have enabled?
Holistically, yes, you will have a problem, eventually. We just can't predict when.
I have a GT-AX11000 with merlin firmware installed. My configuration are the default with nextdns client installed on the router, but I saw that JFFS custom scripts and configs are enabled by default. should I disable it?
The nextdns client requires custom scripts enabled.
