Kernel panic on rt-ac86u running 384.11
davidlee93
For some reason my router (RT-AC86U) reboots only when I connect my android smartphone (Honor 8 Pro, does not occur with any other smartphone) and this only occurs with skynet installed on the router.
First reboot:
May 5 01:05:05 kernel: _ Reboot message ... _______________________________________________________
May 5 01:05:05 kernel: Kernel panic - not syncing: softlockup: hung tasksCPU: 1 PID: 210 Comm: bcmsw_rx Tainted: P O L 4.1.27 #2Hardware name: Broadcom-v8A (DT)Call trace:[<ffffffc0000876d8>] dump_backtrace+0x0/0x150[<ffffffc00008783c>] show_stack+0x14/0x20[<ffffffc00050859c>] dump_stack+0x90/0xb0[<ffffffc00050642c>] panic+0xe0/0x228[<ffffffc0000f8038>] watchdog+0x0/0x48[<ffffffc0000dcf8c>] hrtimer_run_queues+0x8c/0x1c8[<ffffffc0000dc49c>] update_process_times+0x2c/0x70[<ffffffc0000ea434>]
May 5 01:05:05 kernel: 5b80 ffffffc0 006e3980 ffffffc07420: 38424431 30303030 574f444e 3535363d 52203533 303d5345 20303078 204e59537440: 50475255 4f20303d 28205450 34303230 34423530 32303430 00728d7c ffffffc07460: 19189954 ffffffc0 11318ae0 ffffffc0 80728d77 ffffffc0 00728c20 ffffffc07480: 00738000 ffffffc0 006f4000 ffffffc0 00000140 00000000 00728d78 ffffffc074a0: 00000001 00000000 00738b20 ffffffc0 00000123 00000000 0072f16c ffffffc074c0: 00000004 00000000 17ab7500 ffffffc0 000cc6cc ffffffc0 17ab750
May 5 01:05:05 kernel: 042b0fc>] ip_rcv+0x2c4/0x3b8[<ffffffc0003bb310>] __netif_receive_skb_core+0x628/0xa40[<ffffffc0003be31c>] __netif_receive_skb+0x2c/0x88[<ffffffc0003be3b8>] netif_receive_skb_internal+0x40/0xc0[<ffffffc0003be448>] netif_receive_skb_sk+0x10/0x18[<ffffffc0004f29a8>] br_hand
May 5 01:05:05 kernel: usb 3-1: new high-speed USB device number 2 using ehci-platform
May 5 01:05:05 kernel: 2.168.50.210 DST=117.78.54.184 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6118 DF PROTO=TCP SPT=43172 DPT=443 SEQ=2720275094 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40402080A04FC20400000000001030308) [<ffffffc0000af6b0>] kthread+0xd8/0xf0CPU0: stoppingCPU: 0 PID: 0 Comm: swapper/0 Tainted: P O L 4.1.27 #2Hardware name: Broadcom-v8A (DT)Call trace:[<ffffffc0000876d8>] dump_backtrace+0x0/0x150[<ffffffc00008783c>] show_stack+0x14/0x20[<ffffffc00050859c>] dump_stack+0
May 5 01:05:05 kernel: 80: 05f5e100 00000000 170ff921 ffffffc0 19189954 ffffffc0 112477e0 ffffffc0f2a0: 170ffbff ffffffc0 006df3e8 ffffffc0 0063db88 ffffffc0 00542a00 ffffffc0f2c0: 000002de 00000000 005429e8 ffffffc0 170ff921 ffffffc0 0063db88 ffffffc0f2e0: 170ff921 ffffffc0 006eb238 ffffffc0 170ffbff ffffffc0 006df330 ffffffc0f300: 002a42e0 ffffffc0 006df330 ffffffc0[<ffffffc000083da8>] el1_irq+0x68/0xd8[<ffffffc0002a42e0>] vsnprin
May 5 01:05:05 kernel: eth0 (Int switch port: 3) (Logical Port: 3) Link UP 1000 mbps full duplex
May 5 01:05:06 kernel: tf+0x80/0x630[<ffffffc0004051f8>] nf_log_buf_add+0x78/0xd8[<ffffffc000419edc>] nf_log_dump_tcp_header+0x1b4/0x340[<ffffffc00047f7f8>] dump_ipv4_packet+0x2d0/0x670[<ffffffc00047fc5c>] nf_log_ip_packet+0xc4/0x1a0[<ffffffc000405084>] nf_log_packet+0xbc/0xf0[<ffffffc00041f8c4>] log_tg+0x54/0x68[<ffffffc0004812d8>] ipt_do_table+0x2b0/0x400[<ffffffc000484238>] iptable_raw_hook+0x28/0x60[<ffffffc0004048f4>] nf_iterate+0x94/0xa8[<ffffffc0004049b8>] nf_hook_slow+0xb0/0x160[<ffffffc00042b
May 5 01:05:06 kernel: 0x2a8[<ffffffc0000973f8>] __do_softirq+0x100/0x238[<ffffffc0000977f4>] irq_exit+0x9c/0xe0[<ffffffc0000cddb0>] __handle_domain_irq+0x60/0xb8[<ffffffc000080c20>] gic_handle_irq+0x38/0x90Exception stack(0xffffffc0006dfd80 to 0xffffffc0006dfea0)fd80: 49a37a23 00000041 1ffd92f0 ffffffc0 006dfec0 ffffffc0 003721bc ffffffc0fda0: 49a37a23 00000041 6b3b8218 001ce2d4 0008e033 00000000 13ffbf11 00000000fdc0: 0000bd06 00000000 00000018 00000000 af9191b5 001c3152 5205641c 00000041fde0: 006ee
May 5 01:05:06 kernel: ____________________________________________________________________________
May 5 01:05:06 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_inet6addr_event,202: Could not rdpa_ucast_ipv6_host_address_table_find^[[0m
Second reboot:
May 5 01:05:05 kernel: 0007 00000000 00000001 00000000b600: 00395b80 ffffffc0 006e3980 ffffffc0 30303045 30303030 35363d57 20353335b620: 3d534552 30307830 4e595320 47525520 20303d50 2054504f 30323028 42353034b640: 30343034 30383032 00728d7c ffffffc0 19265154 ffffffc0 111f87e0 ffffffc0b660: 80728d77 ffffffc0 00728c20 ffffffc0 00738000 ffffffc0 006f4000 ffffffc0b680: 00000140 00000000 00728d78 ffffffc0 00000001 00000000 00738b20 ffffffc0b6a0: 00000124 00000000 00735438 ffffffc0 00000004 00000000 192cb6f
May 5 01:05:05 kernel: 49b8>] nf_hook_slow+0xb0/0x160[<ffffffc00042b0fc>] ip_rcv+0x2c4/0x3b8[<ffffffc0003bb310>] __netif_receive_skb_core+0x628/0xa40[<ffffffc0003be31c>] __netif_receive_skb+0x2c/0x88[<ffffffc0003be3b8>] netif_receive_skb_internal+0x40/0xc0[<ffffffc0003be448>] netif_receive_skb_sk+0x10/0x18[<ffffffbffc3689e4>]
May 5 01:05:05 kernel: bcm63xx_enet_rx_thread+0x7b4/0xce0 [bcm_enet][<ffffffc0000af6b0>] kthread+0xd8/0xf0CPU0: stoppingCPU: 0 PID: 0 Comm: swapper/0 Tainted: P O L 4.1.27 #2Hardware name: Broadcom-v8A (DT)Call trace:[<ffffffc0000876d8>] dump_backtrace+0x0/0x150[<ffffffc00008783c>] show_stack+0x14/0x20[<ffffffc00050859c>] dump_stack+0x90/0xb0[<ffffffc00008e730>] handle_IPI+0x190/0x1a0[<ffffffc000080c70>] gic_handle_irq+0x88/0x90Exception stack(0xffffffc0006dfd80 to 0xffffffc0006dfea0)fd80:
May 5 01:05:05 kernel: : 006d72e8 ffffffc0 00713ce0 ffffffc0 00517000 ffffffc0 006dc000 ffffffc0fe80: 006d8000 ffffffc0 006dfec0 ffffffc0 003721b4 ffffffc0 006dfec0 ffffffc0[<ffffffc000083da8>] el1_irq+0x68/0xd8
May 5 01:05:05 kernel: ____________________________________________________________________________
May 5 01:05:05 kernel: ^[[0;33;41m[ERROR pktrunner] runnerUcast_inet6addr_event,202: Could not rdpa_ucast_ipv6_host_address_table_find^[[0m
