I've been unable to get policy routing working properly with two VPNs, with either the stable build or alpha 3.
Without any scripts (I removed them to debug the issue and rule out the scripts), the DNS doesn't get forced without DNSFilter (even on alpha 3 it will use OpenDNS). Also, if I stop the VPN, the clients just use the WAN even though I set the drop clients when tunnel down option.
I also seem to get IP/Route conflict warnings, although both VPNs are active and routing the clients as defined (but no working kill switch).
