The Cable is new, but i´ll try another one.It's not a bug. Try replacing your cables
Every new stable Firmware since one year or so.You don't say what firmware versions you have tried ("new" doesn't mean anything)
NetSpeedMonitor and Transferrate in Windows 10You don't say how you are determining the 100Mbit/s speed
LAN only 100Mbit/s is the Title...You don't say whether it's WAN or LAN
Windows 10 PC with Intel 1Gbit/s Network onboardYou don't say what equipment you are connecting to
Nothing, because i thought it´s a bugYou don't say what you have done to try and isolate the problem
Yes i did.Have you reset the router to factory defaults and tried again?
So it's LAN to LAN connections only, not WAN to LAN.LAN only 100Mbit/s is the Title...
So to be clear, your issue is that your PC's network adapter is connecting at 100Mbps instead of 1000Mbps?My Gbit-LAN-PC is connected on LAN 1 with 100Mbit/s.
I can´t belive it... my LAN1 is damagedTry plugging the cable into a different LAN port in case LAN1 is damaged.
Well at least you found the cause before you started buying new hardware. Not too much of a problem I imagine if you only have one wired device.I can´t belive it... my LAN1 is damaged![]()
Welcome To SNBForums
