Local PyTivo Transfers Kill Internet Connection - Asus AC-66R
mafuboys
I have a bit of a strange setup at the moment.
Connected to the internet via cat5e cable I have an Asus AC-66R router with merlin.
Connected to the router I have a powerline network that is 100mbps not gigabit. Connected on the other end of the powerline network is an Asus AC-68R router with stock firmware in AP mode.
Most times when I attempt to transfer something to my Tivo via pyTivo connected to the AC-68R wirelessly, the connection between the cable modem (SB6141) and the asus router AC-66R goes a bit haywire. I need to play around with a hard reset, and sometimes I even need to connect a computer directly to the modem, then reset everything again, and reconnect the modem to the router.
I have no idea what is happening, and why an internal transfer (several gigs) would kill my router's WAN connection, but it is unbelievably frustrating!
Below are logs from Merlin and the cable modem. I can't make sense of them really, and was hoping someone can help.
Asus Logs
Jun 14 21:29:31 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:29:31 kernel: br0: topology change detected, propagating
Jun 14 21:30:31 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:30:31 kernel: br0: topology change detected, propagating
Jun 14 21:31:55 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:31:55 kernel: br0: topology change detected, propagating
Jun 14 21:32:32 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:32:32 kernel: br0: topology change detected, propagating
Jun 14 21:33:03 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:33:03 kernel: br0: topology change detected, propagating
Jun 14 21:34:12 dnsmasq-dhcp[357]: DHCPREQUEST(br0) 192.168.1.195 00:1e:c2:dd:c6:5b
Jun 14 21:34:12 dnsmasq-dhcp[357]: DHCPACK(br0) 192.168.1.195 00:1e:c2:dd:c6:5b Eves-iPhone
Jun 14 21:36:07 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:36:07 kernel: br0: topology change detected, propagating
Jun 14 21:37:13 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:37:13 kernel: br0: topology change detected, propagating
Jun 14 21:37:25 dnsmasq-dhcp[357]: DHCPREQUEST(br0) 192.168.1.62 ac:22:0b:60:27:bd
Jun 14 21:37:25 dnsmasq-dhcp[357]: DHCPACK(br0) 192.168.1.62 ac:22:0b:60:27:bd android-675621f79aabbb39
Jun 14 21:38:31 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:38:31 kernel: br0: topology change detected, propagating
Jun 14 21:39:24 dnsmasq-dhcp[357]: DHCPREQUEST(br0) 192.168.1.104 ac:7b:a1:4a:28:b5
Jun 14 21:39:24 dnsmasq-dhcp[357]: DHCPACK(br0) 192.168.1.104 ac:7b:a1:4a:28:b5 DUBOYS_PC
Jun 14 21:40:23 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:40:23 kernel: br0: topology change detected, propagating
Jun 14 21:43:23 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:43:23 kernel: br0: topology change detected, propagating
Jun 14 21:44:48 dnsmasq-dhcp[357]: DHCPREQUEST(br0) 192.168.1.87 1c:69:a5:d1:9f:2d
Jun 14 21:44:48 dnsmasq-dhcp[357]: DHCPACK(br0) 192.168.1.87 1c:69:a5:d1:9f:2d BLACKBERRY-91F5
Ju
Jun 14 21:46:05 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:46:05 kernel: br0: topology change detected, propagating
Jun 14 21:48:33 kernel: br0: neighbor 8000.38:2c:4a:50:07:d0 lost on port 1(vlan1)
Jun 14 21:48:33 kernel: br0: topology change detected, propagating
Jun 14 21:49:20 dnsmasq-dhcp[357]: DHCPREQUEST(br0) 192.168.1.195 00:1e:c2:dd:c6:5b
Jun 14 21:49:20 dnsmasq-dhcp[357]: DHCPACK(br0) 192.168.1.195 00:1e:c2:dd:c6:5b Eves-iPhone
Jun 14 21:59:05 dnsmasq-dhcp[357]: DHCPREQUEST(br0) 192.168.1.195 00:1e:c2:dd:c6:5b
Jun 14 21:59:05 dnsmasq-dhcp[357]: DHCPACK(br0) 192.168.1.195 00:1e:c2:dd:c6:5b Eves-iPhone
Jun 14 22:02:24 kernel: eth2: received packet with own address as source address
Jun 14 22:03:54 dnsmasq-dhcp[357]: DHCPREQUEST(br0) 192.168.1.104 ac:7b:a1:4a:28:b5
Jun 14 22:03:54 dnsmasq-dhcp[357]: DHCPACK(br0) 192.168.1.104 ac:7b:a1:4a:28:b5 DUBOYS_PC
Jun 14 22:04:43 rc_service: httpd 358:notify_rc restart_wan_if 0
Jun 14 22:04:44 dnsmasq[357]: read /etc/hosts - 5 addresses
Jun 14 22:04:44 dnsmasq[357]: using nameserver 209.18.47.62#53 for domain local
Jun 14 22:04:44 dnsmasq[357]: using nameserver 209.18.47.62#53 for domain nyc.rr.com
Jun 14 22:04:44 dnsmasq[357]: using nameserver 209.18.47.61#53 for domain local
Jun 14 22:04:44 dnsmasq[357]: using nameserver 209.18.47.61#53 for domain nyc.rr.com
Jun 14 22:04:45 kernel: Attempt to kill tasklet from interrupt
Jun 14 22:04:45 kernel: br0: port 1(vlan1) entering disabled state
Jun 14 22:04:45 kernel: br0: port 1(vlan1) entering listening state
Jun 14 22:04:45 kernel: br0: port 1(vlan1) entering learning state
Jun 14 22:04:45 miniupnpd[481]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Jun 14 22:04:45 miniupnpd[481]: Failed to get IP for interface eth0
Jun 14 22:04:45 miniupnpd[481]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Jun 14 22:04:45 kernel: br0: topology change detected, propagating
Jun 14 22:04:45 kernel: br0: port 1(vlan1) entering forwarding state
Jun 14 22:04:45 dnsmasq[357]: read /etc/hosts - 5 addresses
Jun 14 22:04:45 dnsmasq[357]: using nameserver 209.18.47.62#53 for domain local
Jun 14 22:04:45 dnsmasq[357]: using nameserver 209.18.47.62#53 for domain nyc.rr.com
Jun 14 22:04:45 dnsmasq[357]: using nameserver 209.18.47.61#53 for domain local
Jun 14 22:04:45 dnsmasq[357]: using nameserver 209.18.47.61#53 for domain nyc.rr.com
Jun 14 22:05:01 WAN Connection: ISP's DHCP did not function properly.
Jun 14 22:05:01 stop_nat_rules: apply the redirect_rules!
Cable Modem Logs (Everything for June 14th)
Time Priority Code Message
Jun 14 2015 20:26:24 6-Notice I401.0 TLV-11 - unrecognized OID;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
Jun 14 2015 20:26:24 5-Warning Z00.0 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:14 6-Notice N/A Cable Modem Reboot due to power reset ;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0;
Jun 14 2015 20:12:33 6-Notice I401.0 TLV-11 - unrecognized OID;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
Jun 14 2015 20:12:33 5-Warning Z00.0 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:15 6-Notice N/A Cable Modem Reboot due to power reset ;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0;
Jun 14 2015 20:09:24 6-Notice I401.0 TLV-11 - unrecognized OID;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
Jun 14 2015 20:09:24 5-Warning Z00.0 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:15 6-Notice N/A Cable Modem Reboot due to power reset ;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
Jun 14 2015 12:11:25 6-Notice D106.0 DHCP Renew - lease parameters time server-24.29.158.10;tftp file-?BEWGC0LcRRehgqgKKLyv@Cii8r8llUM0Z9Ahe1Qiw1SHEvftfT+ZM modified;CM-MAC=dc:45:17:a1:82:a8;CMTS-MAC=00:17:10:88:9f:28;CM-QOS=1.1;CM-VER=3.0;
