Hey folks,
I'm working through some testing and I'm trying to create a simple batch file that runs through multiple networking tests and spits the results out into a log file. One of the tools I'd like to use the Max Session Tool here on the site.
http://www.smallnetbuilder.com/mydownloads/max_session_tool.zip
Tool works great, but for the life of me I can't figure out how to pipe the output into a log file. I've figured out that I can dump all the data into a file, but then I get a log full of numbers as it writes every session number into the file.
Does anyone know how I can pipe just the final 'failed' packet line into a log file?
For example, with this command I get a blank log file created:
But if I change it to redirect the Standard Error Stream with the following command:
I get a huge log file that logs every single open session number. (I cut out all the numbers between 50 and 40890, but they're in the log)
client 192.168.10.105 12345 192.168.10.20 12345 > test.txt
client 192.168.10.105 12345 192.168.10.20 12345 2> test.txt
http://matrix21.myweb.hinet.net
Send UDP packets from 192.168.10.105(12345+) to 192.168.10.20(12345)
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950...4089040891 WinSock Error# function: Bind(), error code:10013
