MoCA Compatibility question
i could not find the specs for signal pass between the output ports which is required for MOCA compatibility. It looks like a splitter only which would block signal between the output ports.
You can try it, but make sure you can return with no penalty. Otherwise, get a device that specifically is designed and rated for MOCA 2.
