ModSyslogUI v1.0.2 [UPDATE] - add-on providing System Log page UI filtering capabilities
kstamand
Updated 31-Jan-2026.
Be sure to run UPDATE option from script menu, to get the latest release!!
v1.0.2 (31-Jan-2026) - Avoid duplicate or conflicting updates
- Update: Added code to check and remove potential duplicate custom mount points used by script
- Update: Added check to preserve user customizations to logFilter.json if / when Update function is run
Source Code Change Log
ModSyslogUI - Customize router's "System Log" page with custom filtering capabilities​
About:​
The default filtering capabilities of what is displayed on the System Log page of the router is limited to hardcoded text strings in a file called "logFilter.json". This script adds a capability to edit that file to your likings.
This script also updates the System Log page of the Router UI to include dynamic filtering capabilities to:
  • Include all log records, which is the default function, including exclusions noted in logFilter.json
  • Include only log records containing the string or strings of text you chose (separate each by a comma)
    Example - to include all Skynet and Diversion log records only, enter Skynet,Diversion (no spaces after comma)
  • Exclude all log records containing the string or strings of text you chose (separate each by a comma)
    Example - to exlcude all Skynet log records that where blocked, enter the string BLOCKED
  • Filter log records to be displayed using the logical operators AND or OR or AND NOT
    Example - show only kernel errors, enter kernel AND error
This script has been developed under Asuswrt-Merlin 3006.102.6 firmeware and tested on the following routers:
  • RT-BE96U
  • RT-AX88U Pro
  • GT-AX6000
This script DOES NOT equal or replace the functionality that the SCRIBE addon provides.
Instead, it is a simpler lightweight addon that only utilizes the native capabilities of the router.
IT IS NOT RECOMMENDED TO INSTALL THIS SCRIPT AND SCRIBE AT THE SAME TIME. CHOOSE ONE OR THE OTHER
Overview:​
  • Installs script onto router to add filtering capabilities to the routers "System Log" UI page
  • The script provides an interactive manu of options to perform various script maintenance functions
  • Custom System Log filtering capabilities added with this script include:
    1. Hardcoded Filtering - By default, the System Log page filters log records to display based on the contents of a "logFilter.json" file. This script includes an EDIT option that allows you to customize to your liking.
    2. Dynamic Filtering - The System Log page is modifed to allow you to interactively select which log records to INCLUDE or EXCLUDE, with the default action of filtering records based on the contents of the logFilter.json file
    Hardcoded Filtering changes are made from an SSH session to the router, and choosing option 5 from the modsyslogui menu
    Install:​
    Requires Asuswrt-Merlin and JFFS enabled
    SSH to the router and enter:
    /usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/kstamand/modsyslogui/master/modsyslogui" -o "/tmp/modsyslogui" && chmod +x /tmp/modsyslogui && sh /tmp/modsyslogui install
    Configuration:​
    No configuration is required, unless you want to edit the default contents of the "logFilter.json" file --> option 5 from the modsyslogui menu.
    The default contents of the logFilter.json file are:
             "filter": [
             "already exist in UDB, can't add it",
             "not mesh client, can't update it's ip",
             "not exist in UDB, can't update it",
             "send_redir_page"
    To edit this file, add one line for each string from a given log record you want to exclude assocated log records from being displayed
    - string needs to be enclosed in quotes ("")
    - each line, except the last line of the list of filtering strings, must end in a comma (,)
    Example custimized logFilter.json file, to exclude all wireless events ("wlceventd"), Diversion records ("Diversion:"), and Skynet BLOCKED records ("BLOCKED"):
            "filter": [
               "send_redir_page",
               "wlceventd",
               "Diversion:",
               "BLOCKED"
    TIPS
    ALL System log records, generally start with a script function name. Examples;
    • The majority of ADDON script contributors prefix their log records with the name of their script (e.g., Diversion, Skynet, Scribe, ...)
    • Other than that, scan log records for unique strings from a given record to inlude / exclude, such as
      - wireless events (leaving or joining) = wlcevented
      - ethernet connected devices powering on or shutting down (entering listening | learning | forwarding state)
      - specific addon scripts (e.g., log records starting with modsyslogui)
    Command line usage:​
    Once installed, from a terminal ssh session into the router, enter the command modsyslogui and choose from one of the menu options:
    To skip displaying the menu, you can run select options directly by running modsyslogui with one of the following parameters;
        - modsyslogui install
        - modsyslogui update
        - modsyslogui enable
        - modsyslogui disable
        - modsyslogui uninstall
    System Log page usage:​
    The System Log page is customized by this script to add a dynamic **Log Filtering Option** box, where you have three options:
    1. Show all log records (default option) - nothing need be entered in the dialog box under the three options. All system log records are displayed, minus those log records matching one of the strings in the logFilter.json file
    2. Include only - enter a string or series of strings separated by a comma, with no spaces, to only show log records matching the string(s)
    3. Exclude containing - enter a string or series of strings separated by a comma, with no spaces, to exclude log records matching the string(s)
Finally a new script that is already amtm compatible during beta. And it looks to be useful.
Just remember @kstamand , when logging is enabled in Diversion, the Dnsmasq output goes to /opt/var/log/dnsmasq.log, not the SysLog.
Does it just filter the data in UI or also prevent the records being actually written to /jffs/syslog.log?
It only filters log records from displaying in the UI, no filtering or changes are applied to syslog.log itself.
Let me know if you have any other questions or if you have any suggestion on updated wording to use in the original posting of this thread to make this clearer
Really like the concept here. Thank you!
Initially I though it wasn't working, but it just needed a moment.
Could it eventually support Boolean uppercase delimiters e.g. Error AND Get (I tried it but it did not seem to.. yet :-)).
Glad to hear you find it useful.
Regarding adding boolean capabilities, most definitely. First I'd like to get through the beta and see if there are any other feature requests / bugs to clean up.
Thanks for the feedback!!
@kstamand Just an academic question; Is it possible to remove the dependency on Entware and a USB drive? In other words have it run entirely standalone from /jffs.
Hmmm. I hadn't thought about that ... do you happen to know if would that prevent the script from being added to AMTM, if it gains enough interest or is that a question for @thelonelycoder?
I don't see why that would exclude it from amtm. amtm itself runs entirely from jffs as did some of the third party addons in the past, e.g. Skynet.
I'm guessing that your code isn't constantly writing to storage while it's working?
Like I said, it's only an academic question for me. But as a general principle I try to avoid introducing any unnecessary dependencies if possible.
Let me put your mind to rest, I have your script on radar.
MerlinAU as an example does not require USB or Entware and is apart of AMTM. Along with others.
Entware and USB dependencies is usually only if the script requires it but would not impact integration with AMTM.
Seeking assistance in trying to add Boolean logic support as @jksmurf asked in post #5 above.
- Can boolean search criteria (e.g., Get AND error) entered in a form input field be used "as-is" (meaning without any parsing/reconstruction) in a javascript .find or .includes method to filter the log records? If yes, can anyone point me to a working example?
- If the form input field can't be used 'as-is", is there another approach I can use other than using the split(" ") method into unique fields (e.g., string1, boolean_operator, string2), followed by some if then logic on the boolean_operator to build the appropriate .find or .includes method to filter the log records? If yes, kindly point me to some working examples for reference?
Thanks in advance
Thanks in advance
My initial suggestion would be to first clearly define the syntax that the input field will accept as valid entries.
1) Define the keywords to be used as valid boolean operators.
Examples: all upper cases OR, AND, NOT (??).​
2) Define the basic syntax of the boolean expressions that the input field will accept as valid.
Examples:​
"string01" OR "string02"
"string01" AND "string02"
"string01" AND NOT "string02"
3) Define if the input field will accept compound boolean expressions.
Examples:​
"string01" OR "string02" OR "string03" OR "string04"
"string01" AND "string02" AND "string03" AND "string04"
"string01" AND "string02" AND "string03" AND NOT "string04"
("string01" AND "string02") OR ("string03" AND "string04")
Once you have settled on the valid syntax and grammar rules, those will dictate how you implement the code.
But in any case, accepting the input field "as is" "(meaning without any parsing/reconstruction)" is not really feasible or recommended because you will always need to parse the input strings anyway; first, just to check they contain a valid syntax for a boolean expression; and second, to "sanitize" the string values before feeding them to the appropriate JavaScript functions that will perform the logical operations.
Just my 2 cents.
@Martinski thanks for the feedback. That is the path I am on already, but figured I'd ask the community before I go too far down that path.
Thanks again
@jksmurf - I've added basic logical expression filtering capabilities (AND or OR or AND NOT). Uninstall, then reinstall modsyslogui and give it a shot. Hopefully that meets your needs.
@ColinTaylor I realize your question was just academic, but I believe the code is not dependent on Entware and a USB.
Unless I'm overlooking something in my code, the only portion of code that may be related is where I'm adding an alias for modsyslogui ==> that section checks if the /opt/bin directory exists (which I believe only exists if entware is installed which requires a USB) and if not, it then adds the alias to profile.add instead. The intent was to be able to add an alias whether entware was or wasn't installed.
Was there a dependency somewhere else in the code I'm overlooking?
Thank you for looking into this.
1. Uninstall worked fine, reinstall only with the complete curl line, is that expected ?
2. Minor type in text box?
3. But are you saying it will not work with TWO words with AND or OR, ONLY 3-4?
4. Tried 3 words but couldn’t not seem to get it to work ?
Sorry if I’m not doing something correctly here?
FYI
Just playing with updates. If it’s up to date, might not need to proceed with updates?
@jksmurf I don't see a typo myself and the meaning appears clear.
EDIT: Do you mean the capital C in the "blah blah blah Contains" error message?
In your case the line you're entering is invalid. You could use:
hostap AND wl0.1
or
hostap AND NOT wl0.1
Note that it's wl not w1.
Sorry, was just a space before the word “Contains”, so assumed a typo of some kind that makes it do that, or formatting. I’m not a coder by any stretch, so I’m just reporting what I see in the text boxes that come up.
hostap AND wl0.1
or
Doh. That’ll teach me. I’m on an iPad propped up in bed.
But if it’s mistyped then surely it’s a null result, which is not what I got?
And what logical operators am I using that are incorrect. See error messages in the white boxes.
I’m not actually searching for anything I’m just testing, as requested, but even when I correct it I’m getting the messages, but not the correct filter?
If I’m inputting things incorrectly here I’m happy to be pointed in the right direction, especially if my trials work for others without the messages.
