Seems like I am the only one with the RT-AX58U router blues. Crashes multiple times some days. Currently on Beta 5. Not using scripts, USB drive. Just running traffic. Attached is a crash log. Would appreciate some additional eyes on this to see if I have a HW or SW fault.
I have similar problems.So what happens after you upgrade to the Final Release?
Release - Asuswrt-Merlin 386.1 is now available
Feb 12th: 386.1_2 is now available: 386.1_2 (12-Feb-2021) - NEW: Added snmp support to the RT-AX86U. - UPDATED: inadyn to 2.8.1. - UPDATED: nano to 5.5. - CHANGED: Use local OUI database instead of remote one hosted on Asus's server (allows queries to work even when...www.snbforums.com
And what happens if you only use IPV4?
If you are forwarding the logs to Asus, while running Merlin firmware, it’s unlikely they are even looking at them.I have similar problems.
Using latest firmware (386.?) the router crashes. I always reset the router twice - button & GUI before and after updating.
Upgraded to 386, next morning router had restarted at least once (IP changed), during the AM the router crashed at least 5 times (that's all I noted). I can see the router, when it crashes all the lights go out and it restarts.
Have tried other versions of ASUS and Merlin firmware for my router 384.17 is the most reliable. I just worked backwards 'till I found one that appeared to be stable.
No longer have my notes however other versions (between 384.17 and latest) also cause problems. The problems range from crashes to out of memory. The out of memory errors take a few days. I keep an on the free memory and it slowly decreases to zero, shortly after the router will restart. I have forwarded some of the logs to ASUS via the GUI, it is clear the router is out of memory from the entries in the log file.
AX58u has been stable for 2 days with 384.17(Merlin) memory at 59% free, QOS enabled.
Logs have only been sent to ASUS from their firmware (I believe that the logs can only be forwarded to Asus from their GUI). Have tried most versions of ASUS & Merlin firmware. Problem has been reported to ASUS. Had a bit of trouble with the serial number, ASUS site kept saying invalid. Took me awhile to figure out that what I thought was a 1(one) was an I(upper case i).If you are forwarding the logs to Asus, while running Merlin firmware, it’s unlikely they are even looking at them.
Welcome To SNBForums
