Need Advice - 140m Ethernet Run Between Buildings
Reda
Hey community,
I'm facing a technical challenge and could really use your expertise. I need to establish a wired network connection between two points 140 meters apart - well beyond the standard 100m limit for Ethernet.
Key Details:
  • Outdoor installation (connecting two separate buildings)
  • Requires stable, reliable bandwidth
  • Must be wired (WiFi isn't suitable for this application)
Looking for real-world experience:
  1. Has anyone successfully implemented a similar long-distance run?
  2. What solutions actually worked in practice?
  3. Any pitfalls or lessons learned I should know about?
I'm especially interested in hearing about what's worked (or failed) for others in field deployments.
Thanks in advance for sharing your knowledge!
PS: I'm aware fiber is an option, but curious about other approaches that might work with just rj45 cables.
It would work but possibly with reduced bandwidth...
However, you risk the probable issue with dissimilarities with the electrical system between the two buildings. Fiber does not conduct and would be the better way to go.
There are also some good wireless options available today that would give you high bandwidth.
What bandwidth and reliability is required ?
Point to point 2.4 GHz can go very long line-of-sight due to the narrow beam transmission. Rain or fog is the only weather that can reduce the RF power. Otherwise, fiber, direct burial or aerial rated/designed if you need higher bandwidth. You might get 100 Mbit/s reliably using CAT 5e direct burial cable. Has to be moisture blocking cable.
Ground loop would be a real concern unless the earthing point is provided only at one of the building. The potential difference between the two grounding locations can destroy electronic gear. Single earthing unlikely to be allowed, given the distance.
Coax is another possibility, but again, you have to get the earthing of the shield correct and avoid ground loops.
Fiber is the most realistic, inexpensive solution.
Hey community,
Key Details:
The distance is outside specs but possibly close enough to work. Buy quality cable with solid copper conductors in the length you need and test data rate. If good enough bury/install the cable between buildings. Install Ethernet surge protectors at both ends of the cable, If possible and needed install unmanaged switches as near the beginning and end of the 140 meter run to effectively act as amplifiers.
I think you're being way too quick to dismiss the wireless approach. Point-to-point wifi like Ubiquiti's UISP gear can reach gigabit-ish throughput and will probably cost less than trenching a cable. If you do insist on a wired solution, though, I concur with the other responses recommending fiber. Copper between two separate buildings creates too many hazards.
There is a new model bridge in UniFi section, can do up to 6Gbps:
Yeah, but I'd only recommend the UBB if the user wants to buy into the UniFi ecosystem. Otherwise, the 60GHz "Wave" series from the UISP product line makes more sense, IMO anyway. I've not used those models myself, but if they are like other UISP PtP radios, they don't require any extra configuration infrastructure.
Trenched Fiber - this is the way...
