Need help with OpenLDAP
Mogsy
HI guys. My bootcaches plist and AppleOpenLDAP.plist might have been tempered with. Anyone can help me verify? Pointless to talk to Apple Support. I was a bit shock to see Open Directory was used to look up devices. If this is normal then fine, but if not what should I do :eek:
Tons of bridgeOS requirement not met logs. Can't install Windows from bootcamp on M1 :rolleyes::rolleyes::rolleyes:
Not sure if I should copy paste the plists here but the OpenLDAP is less harmless than the boot caches I think. I installed Parallel before. Uninstalled it, then rebooted the Mac. I guess I didn't uninstall correctly. Tons of crashing apps on iPhone that dependent on the same frameworks. The plist is too long, here are some of the info
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
    <key>Attribute Type Map</key>
    <array>
        <dict>
            <key>Native Map</key>
            <array>
                <string>cn</string>
            </array>
            <key>Standard Name</key>
            <string>dsAttrTypeStandard:RecordName</string>
        </dict>
        <dict>
            <array>
                <string>createTimestamp</string>
            </array>
            <string>dsAttrTypeStandard:CreationTimestamp</string>
        </dict>
        <dict>
            <array>
                <string>modifyTimestamp</string>
            </array>
            <string>dsAttrTypeStandard:ModificationTimestamp</string>
        </dict>
    </array>
    <key>Map Search Base</key>
    <string>cn=config, %!</string>
    <key>Record Type Map</key>
    <array>
        <dict>
            <array>
                <dict>
                    <array>
                        <string>authGUID</string>
                    </array>
                </dict>
                <dict>
                    <array>
                        <string>draft-krbACL</string>
                    </array>
                    <string>dsAttrTypeStandard:KerberosACL</string>
                </dict>
                <dict>
                    <array>
                        <string>draft-krbKeySet</string>
                    </array>
                    <string>dsAttrTypeStandard:KerberosKeySet</string>
                </dict>
                <dict>
                    <array>
                        <string>draft-krbPrincipalACL</string>
                    </array>
                    <string>dsAttrTypeStandard:KerberosPrincipalACL</string>
                </dict>
                <dict>
                    <array>
                        <string>draft-krbPrincipalAliases</string>
                    </array>
                    <string>dsAttrTypeStandard:KerberosPrincipalAliases</string>
                </dict>
                <dict>
                    <array>
                        <string>draft-krbPrincipalName</string>
                    </array>
                    <string>dsAttrTypeStandard:KerberosPrincipalName</string>
                </dict>
                <dict>
                    <array>
                        <string>draft-krbTicketPolicy</string>
                    </array>
                    <string>dsAttrTypeStandard:KerberosTicketPolicy</string>
                </dict>
            </array>
            <array>
                <dict>
                    <key>Group Object Classes</key>
                    <string>OR</string>
                    <key>Object Classes</key>
                    <array>
                        <string>pwsAuthdata</string>
                    </array>
                    <key>Search Base</key>
                    <string>cn=users, cn=authdata</string>
                </dict>
            </array>
            <string>dsRecTypeStandard:UserAuthenticationData</string>
        </dict>
        <dict>
            <array>
                <dict>
                    <array>
                        <string>uid</string>
                        <string>cn</string>
                    </array>
                </dict>
                <dict>
                    <array>
                        <string>cn</string>
                    </array>
                    <string>dsAttrTypeStandard:RealName</string>
                </dict>
                <dict>
                    <array>
                        <string>uidNumber</string>
                    </array>
                    <string>dsAttrTypeStandard:UniqueID</string>
                </dict>
                <dict>
                    <array>
                        <string>gidNumber</string>
                    </array>
                    <string>dsAttrTypeStandard:PrimaryGroupID</string>
                </dict>
                <dict>
                    <array>
                        <string>homeDirectory</string>
                    </array>
                    <string>dsAttrTypeStandard:NFSHomeDirectory</string>
</dict>
                <dict>
                    <array>
                        <string>shadowExpire</string>
                    </array>
                    <string>dsAttrTypeStandard:Expire</string>
                </dict>
                <dict>
                    <array>
                        <string>authAuthority</string>
                    </array>
                    <string>dsAttrTypeStandard:AuthenticationAuthority</string>
                </dict>
                <dict>
                    <array>
                        <string>apple-user-authenticationhint</string>
                    </array>
                    <string>dsAttrTypeStandard:AuthenticationHint</string>
                </dict>
                <dict>
                    <array>
                        <string>apple-user-passwordpolicy</string>
                    </array>
                    <string>dsAttrTypeStandard:PasswordPolicyOptions</string>
                </dict>
                <dict>
                    <array>
                        <string>acctFlags</string>
                    </array>
                    <string>dsAttrTypeStandard:SMBAccountFlags</string>
                </dict>
                <dict>
                    <array>
                        <string>pwdLastSet</string>
                    </array>
                    <string>dsAttrTypeStandard:SMBPasswordLastSet</string>
                </dict>
                <dict>
Ohhh kay. I get the idea now :D:D
What a mess. I hate my job for having to hop between mac and windows and I havent used mac for awhile *dead
In need of assistance please...
I wanted to clean my computer's hard drive. Are there any free computer cleaning software packages I might download? There are several paid programmes available bad bunny merch shop, but I was looking for free one. How can I restore my operating system?
