ddaenen1
OK, this might be a lengthy post as i am not an experienced network builder and probably even need to learn the jargon.
Up until recently (like in last Saturday), i had a home network consisting of an Asus RT-AC88u wireless router connected to 200Mbps cable modem (with a static IP) and the integrated 8-port switch hard wired to a Samsung smart TV, my ReadNAS RN212, another non-smart Samsung TV and 2 AP's, one Linksys EA6400, one Linksys XC1900 (both configured in bridge mode) and even an older server tower mainly used for Plex streaming (all hardwired devices are configured with static IP's) and all was working fairly ok with the exception of the Asus router which always had the odd glitch, like not wanted to connect my wireless HP printer to my wireless laptop, dropping the connection with one of the AP's and so on...Wireless devices are plenty in the house included several Macbook air's, iPads, iPhones, Nintendo Switch, Wii U and even a smart thermostat.
Fact is that with the upcoming installation of solar panels on the roof, i was running out of ports on the switch so i decided to change gears and get some decent networking hardware installed whilst needed to extend the amount of ports (for solar panel inverters, a hardwired UTP connection is recommended). The plan was to keep the 2 Linksys AP's, add a decent switch, router and convert the Asus wireless router into a wireless AP and all of this with the aim to create a state reliable home-network.
As i am not very experienced in building networks, i wasn't looking for the latest hardware but something solid and stable that can last x-amount of years. I bought a Netgear GS724Tv3 switch which i already installed and soon will add a EdgeRouter lite which i am just waiting to arrive. Both i bought 2nd hand via a local site. My choices for this specific hardware were driven by availability closely and various online sources on this hardware.
So far for the introduction...
I have added the Netgear switch to the network and rerouted all hardwired devices to connect to the switch with the Asus only functioning a router with the exception of both TV's that were always connected to the network via the UTP ports of both respective AP's. The switch has been configured with a static ip (192.168.1.2), the default VLAN settings and i configure p15 & p16 in LAG to support the LACP link aggregation capability of the ReadyNAS. For the rest i left everything on default except for NTP settings (which still don't work). All, in all, I would say that all worked out fairly well but i do noticed some odd behaviour for which i do not have any remedy.
1. the smart TV (initially DHCP enabled) was still connected to the network but couldn't get the gateway (192.168.1.1) yesterday. I fixed that by configuring it as a static IP with 192.168.1.1 gateway and 8.8.8.8 / 8.8.4.4 DNS servers and after that all was working again.
2. When i close a laptop and re-open it again, the wifi connects instantly but it takes up to 30 seconds before i have internet connection with existing windows that were open in the browser. If i open a new browser window and go to a different site, that works instantly. I have only seen this behavior with laptops and even with my old Plex server when it came out of sleep mode. Not have seen this with iPads or iPhones.
It is too early if the static config on the smart TV fixed the problem permanently but the big question here is what caused this to happen. What bugs me most is issue no. 2 and probably because i have no clue where to start looking.
Hoping to get some new insights on where to look first and foremost, to learn from the knowledge in this forum and hopefully one day, i can return by providing insights and solutions to others.
Many thanks, Dominique
