My grandparents have asked me to "fix" their wifi coverage. The primary issue is getting signal from their router location to their TV location, opposite ends of the house. Based on attic layout, ethernet isn't practical (nor do they need a ton of bandwith; the most internet they use is streaming Netflix, and if that's going on, it's the only activity on the wifi).
What I have to work with currently:
-1 ATT Uverse router with Wifi ("UVERSE")
-1 Netgear router (N300, I think; might be N600) ("NETGEAR")
-1 current gen Airport Express ("EXPRESS")
Currently the setup is UVERSE ethernet to WAN on NETGEAR, NETGEAR is the functioning router. The EXPRESS isn't being used for anything yet.
If I'm reading the Apple support correctly, I can't use the EXPRESS to act as a wireless repeater for a non-airport router (so UVERSE - ethernet - NETGEAR - wifi -EXPRESS - wifi - CLIENT wouldn't work). Is this correct?
Presuming that is correct, thoughts on this design?
UVERSE - wifi - EXPRESS - ethernet - NETGEAR - wifi2 - CLIENT
Where all clients only connect to wifi2? Or any other idea I should try?
...or should my grandfather be getting an Airport Extreme for father's day (as an early gift) to save me a lot of headache?
...or return the Airport Express for a ...? which would do this simply and reliably?
Chief concern is reliability. Every time this stops working, I'm likely to be getting a phone call.
