Hello all
I'm looking for a solution to improve my network connection to my pellet stove from my home assistant box (Raspberry PI 4)
Currently, my HA box is wired to my local network, and all my automation appliance are on the local network(shelly's etc.)
except my pellet stove, wich is acting like a wifi hotspot, broadcasting an SSID and it has a DHCP server.
My HA box connects to the stove as a client using it's built-in wifi (so this is a different subnet than my local network)
Here lies the problem, this wifi connection is really not stable, the HA OS has a lot of trouble connecting to the stove, I have to do it manually and it require several try to connect.
sometime the connection is lost, and I have to do it all over again, it's a pain.
There are no satisfying solution for this, i've been searching and trying for month, even adding a Wifi usb dongle does not seem to resolve the issue.(but haven't tried)
I don't have any trouble connecting to the stove from my smartphone, or my PC, this is issue is either with the RPI itself or the HA OS (linux based).
So I'm looking for a nice way to add the stove to my lan, like with a client to connect to the stove, which will also be connected to my local network.
Routing will be needed
I have an ISP router connected to internet, as my main internal router is an Asus RT-AC86U running AsusWRT Merlin
Here's 2 drawings of the current situation and target.
I'm looking for a device that will be able to connect as a client to the stove, and connect to my main lan on the other side.
the device should be small, I don't want to buy a real router, it would be a loss of money for this single usage.
The easiest way would be for that device to be able to do routing (maybe a nano router flashed with DD-wrt or openwrt ??)
an other way would be to leave the routing to the RT-AC86U with a VLAN and a different subnet, but as far as I can see since i'm running in router mode I can't do that. (I looked for tutorial for wrt-merlin all over)
Do you have any suggestion for achieving this ?
Thx a lot
Thx a lot
