Jeffrey Young
Hey @Jack Yaz
Trying to track down an issue with my 2.4G connections resetting every so often. At first, I was thinking it was related to the new 386.4 build, but I finally caught the error
This only happens every couple of hours. It is looking like the firewall-start script is getting called when spdmerlin makes a bandwidth change. Just wondering if this is expected, and if so, could it be related to the issues some are having on the new 386.4 build? Does not not seem to bother my system at all.
Any other logs I can send you?
Cheers
networkmap: Error unlocking 11: 9 Bad file descriptor
and networkmap: Error unlocking 0: 9 Bad file descriptor
in the logs while YazFi is starting up. I have attached the logs below. Was wondering if you have any insights or is a JFFS format in order.This only happens every couple of hours. It is looking like the firewall-start script is getting called when spdmerlin makes a bandwidth change. Just wondering if this is expected, and if so, could it be related to the issues some are having on the new 386.4 build? Does not not seem to bother my system at all.
Cheers
Jan 6 14:12:00 RTAC86U spdMerlin: Starting speedtest using Eastlink (Barrie, ON, Canada) for WAN interface
Jan 6 14:12:26 RTAC86U spdMerlin: Speedtest results - Download: 75.58 Mbps (data used: 92.7 MB ) - Upload: 38.92 Mbps (data used: 42.2 MB )
Jan 6 14:12:26 RTAC86U spdMerlin: Connection quality - Latency: 32.58 ms (19.27 ms jitter) - Packet Loss: 0.6%
Jan 6 14:12:26 RTAC86U spdMerlin: Retrieving data for WebUI charts
Jan 6 14:12:32 RTAC86U spdMerlin: Calculated Download speed (72994 Kbps) does not exceed 5% threshold of existing value (73210 Kbps)
Jan 6 14:12:32 RTAC86U spdMerlin: Calculated Upload speed (35211 Kbps) does not exceed 5% threshold of existing value (36455 Kbps)
Jan 6 15:12:00 RTAC86U spdMerlin: Starting speedtest using Eastlink (Barrie, ON, Canada) for WAN interface
Jan 6 15:12:27 RTAC86U spdMerlin: Speedtest results - Download: 75.82 Mbps (data used: 92.9 MB ) - Upload: 31.22 Mbps (data used: 38.3 MB )
Jan 6 15:12:27 RTAC86U spdMerlin: Connection quality - Latency: 25.52 ms (8.99 ms jitter) - Packet Loss: 0.0%
Jan 6 15:12:27 RTAC86U spdMerlin: Retrieving data for WebUI charts
Jan 6 15:12:35 RTAC86U spdMerlin: Calculated Download speed (72913 Kbps) does not exceed 5% threshold of existing value (73210 Kbps)
Jan 6 15:12:35 RTAC86U spdMerlin: Setting QoS Upload Speed to 34400 Kbps (was 36455 Kbps)
Jan 6 15:12:35 RTAC86U rc_service: service 21156:notify_rc restart_qos;restart_firewall
Jan 6 15:12:35 RTAC86U custom_script: Running /jffs/scripts/service-event (args: restart qos)
Jan 6 15:12:35 RTAC86U custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Jan 6 15:12:35 RTAC86U custom_script: Running /jffs/scripts/nat-start
Jan 6 15:12:35 RTAC86U ntpMerlin: Sleeping for 5s to allow firewall/nat startup to be completed...
Jan 6 15:12:35 RTAC86U custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Jan 6 15:12:36 RTAC86U YazFi: Firewall restarted - sleeping 10s before running YazFi
Jan 6 15:12:40 RTAC86U conntrackscript: Value 750 written to nf_conntrack_expect_max, restarting conntrack
Jan 6 15:12:42 RTAC86U rc_service: service 21448:notify_rc restart_conntrack
Jan 6 15:12:42 RTAC86U custom_script: Running /jffs/scripts/service-event (args: restart conntrack)
Jan 6 15:12:42 RTAC86U (nat-start): 21305 Checking if WireGuard is UP....
Jan 6 15:12:46 RTAC86U YazFi: YazFi v4.4.0 starting up
Jan 6 15:12:47 RTAC86U YazFi: wl0.1 (SSID: YoungRestrict) - sending all interface internet traffic over WAN interface
Jan 6 15:12:50 RTAC86U YazFi: Executing user script: /jffs/addons/YazFi.d/userscripts.d/add_post_printer.sh
Jan 6 15:12:50 RTAC86U YazFi: Forcing YazFi Guest WiFi clients to reauthenticate
Jan 6 15:13:01 RTAC86U networkmap: Error unlocking 11: 9 Bad file descriptor
Jan 6 15:13:01 RTAC86U networkmap: Error unlocking 0: 9 Bad file descriptor
Jan 6 15:13:06 RTAC86U YazFi: YazFi v4.4.0 completed successfully
