Newbe question on Firmware
backhoeken
Sorry for asking a newbe question but:
Currently running 3.0.0.3.108 is it worth upgrading the firmware. Not using any usb devices.
Thank you
Ken
Re-enter settings after firmware settings version jump
Hi Ken,
The only "problem" will be, that you should write down (or copy/paste) your settings from the GUI:
As propably many NVRAM settings have changed you need to reset the router (before and after upgrade) to defaults and restart it. :eek:
Then you can re-enter the settings from your writings or copy.
With kind regards
Joe :cool:
B DSL-N66U Probably a stupid question ASUS N Routers & Adapters 3
