No Asus app
Gar
After resetting and re-configuring my 56U the app won't work anymore. Remote access is off but this was the case before, can't figure what has caused this. It says "authentication failed" when I try to log in but the user name/password is correct. I remember the threads about remote access being dangerous so made sure it was off before. Any guesses?
Advanced-> HTTP vs HTTPS, correct port 8443?
That was it, ty! Forgot to change that after reset.
  • Like
Reactions: JDB
Is there a way to disable HTTPS from the app? I can no longer access the router directly via 192.168.1.1
