No VLAN tab on GT-AX11000 pro with GT-AC5300 as AI Mesh node
Yardie
I hope this is the right section.
I have a GT-AX11000 pro as main and GT-AC5300 as AI Mesh node, connected by Cat6 cable. I have no VLAN tab in the LAN section.
-Is this because the 5300 doesn't support VLAN (seems odd given its two physically different devices)?
-Given my setup, would the functionality be available in Merlin - ie is it an Asus firmware issue?
-Is there a way to workaround enable VLAN on the 11000 - eg turn the 5300 off, configure it then turn the 5300 back on? (I'll try it - but if anyone has experience.... please)
I know a cheap DLink managed switch could solve this, but practically - if the 11000 can do the job natively....
Both devices are running stock firmware fully updated at this post
GT-AX11000 Pro have 3.0.0.6 fw ? don't think so
There is no VLAN tab in this firmware. Only in the upcoming 3.0.0.6 Pro firmware, but not released yet for your router.
Update. I investigated the option of using the beta version of the software. It offers mesh AI and VLAN.
Now the 11000 is on on beta version 9.0.0.6.102. The 5300 offered no beta so its on stock 3.0.0.4.386
I got VLAN (access mode, no dhcp) working after some head scratching alongside AI Mesh - the difficulty was that I'd never done it before.
I saw posts elsewhere that said it worked ok and hopefully my experience will be likewise...
The GT-AC5300 is not currently listed as a Guest Network Pro supported router.
2). Guest network pro supported models:
  • GT-AX11000 Pro, GT-AX6000, GT-AXE16000, RT-AX86U Pro, RT-AX88U Pro, ZenWiFi Pro ET12, ZenWIFI Pro XT12, more models are coming.
3). The following feature requires router firmware version later than version 3.0.0.6.102_xxxx or above. Some models provide beta firmware (9.0.0.6.102_xxxx) to experience this feature.
Without testing, it's hard to tell which settings are being sent to the AiMesh node correctly.
The following may or may not be relevant to the discussion.
Edit this also may or may not be relevant. And may not be updated to deal with Guest Network Pro.
I think it will take at least 2-3 years to know how it is supposed to work (which doesn't mean it will work as it should).
