Hi there,
I have an old La Fontenna external wireless Fon antenna from my fonero days. The cable says 50 ohm and 7dbi gain w/o cable loss, it's a 3m/10f cable. Back in the days it was used for B/G extension in the fonero router. I am wondering if I could use it on my Asus N66U AP or the R7000 to extend the range a bit for wireless N at 2.4 ghz or if it's recycling material at this point. I have B/G networks turned off.
I read somewhere there might be differences among antenna for 2.4 or 5Ghz and B/G/N or even AC. I have no clue other than that it a directional antenna. Regarding the three antennas on the N66U I would assume it does not matter which one to replace if it could indeed be used today.
Is it possible? Would this make sense?
Thanks!
Thanks!
