aquafuzz
Current Setup:
Fiber ISP wired to Netgear R7450 #1, from Router #1 (SSID-Home) it is wired to a TV, Bedroom PC and 5 port switch. From the 5 port switch it is wired to my home office PC and to a detached office space where the Netgear R7450 #2 (SSID-Office) is located.
Both routers are configured as if they are a single routers (out of the box setup), no special configuration.
The Issues:
No know issues within the home setup.
In the detached office where I conduct all of my ZOOM meetings I sporadically have "you network connection is unstable" warnings popup on my ZOOM meeting or my ZOOM connection completely disconnects and reconnects (WiFi drops and picks up again). I have had an IP Conflict warning pop up on my PC but after a restart of the PC everything was fine.
I only seem to have issue while in ZOOM. If I am on YT or Netflix or Prime Movies or and other streaming service, no issues.
Speed tests are consistent, 450 down - 450 up, ping 2ms
This began all around the time I upgraded both routers from old ASUS routers to the R7450's and switching ISP's from Sprectrum - cable modem to a local CoOp - fiber (Home Telcom). I upgraded routers to handle the fiber service.
This may not be router related but that's where I'm starting because that's the only thing that has changed recently.
Are there any further tests I can run or things to check before re-configuring routers?
If I have to re-configure my routers, what is the best solution for my setup? I want to have a SSID for each router.
Wiring Layout
Router #1 Home Configuration
Router #2 Office Configuration
The Issues:
Wiring Layout
