Tim and staff,
Method two worked for me! I've been doing some digging (for days) on how to use my existing hardware to do "1 internet connection 2 private LANs article". This is the first time I've been able to do static routing! There seems to be steps missing in the other descriptions on the web, or they just were not quite clear enough for my understanding.
Thanks Tim and staff, I appreciate it!
Now I plan on using at least two downstream wireless routers and possibly three, all connected to the upstream router.
My thinking is to use an EnGenius 9850 for the upstream router, radio off, NAT & SPI on. My thinking is since it can handle so many maximum simultaneous connections it should be the first router after the cable modem. Maybe my thinking is flawed here. As I've not read anywhere, where routers should be placed on their networks based on their maximum simultaneous connections.
The downstream routers will have DHCP and radios on.
Since the NAT and SPI are off in the downstream routers, will something that needs to forward ports, PS3, xBox, be able to do so without having to do messy port forwarding setups? Hoping here for UPnP to work through all of this.
