Hello,
I have a problem with OpenVPN configuration:
Open VPN Server is working properly on my AC68U with 386.1_beta5 and I can connect to it from any device that has the OpenVPN app, and all works as it should.
On my AX88U I've setup the VPN client importing the SAME file (from my AC68U) as in any other OpenVPN app and when I connect I simply loose Internet connection. As soon as I turn off the client Internet comes back. The same thing happens when I try to use the OpenVPN from my friend's AC88U that otherwise works perfectly within the OpenVPN apps on any platform.
I mind you that I've setup the VPN clients for 3 locations with OpenVPN files downloaded from ExpressVPN, that I subscribe to, and they just work flawlessly.
Can anybody help?
Thank you...
Can anybody help?
Thank you...
