I use to have my openvpn server running with no problems in my AC3100
My setup is WAN<>ISP modem<>AC68U<>LAN
I had to change it because the ac3100 was loosing connections
I forwarded UDP 1194 port to my AC68u, exported the OpenVPN configuration file, created two users.
Then, i imported the config file into my android phone, but i have no connection
I tested it with a wrong username/password intentionally, it looks like it never reached my asus router
Here you have my androind openvpn log (changed address to xx)
The DDNS is working as expected
I have no wait to have a log from my ISP modem
10:12:30.793 -- ----- OpenVPN Start -----
10:12:30.793 -- EVENT: CORE_THREAD_ACTIVE
10:12:30.795 -- OpenVPN core 3.git::d3f8b18b:Release android arm64 64-bit PT_PROXY
10:12:30.795 -- Frame=512/2048/512 mssfix-ctrl=1250
10:12:30.795 -- UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
7 [ncp-ciphers] [CHACHA20-POLY1305:AES-128-GCM:AES-256-GCM:AES-128-CBC:AES-256-CB...]
10:12:30.796 -- EVENT: RESOLVE
10:12:30.799 -- Contacting
50.71.XX.XX:1194 via UDP
10:12:30.800 -- EVENT: WAIT
10:12:30.808 -- Connecting to [
XXX.asuscomm.com]:1194 (50.71.xx.xx) via UDPv4
10:12:40.795 -- Server poll timeout, trying next remote entry...
10:12:40.796 -- EVENT: RECONNECTING
10:12:40.799 -- EVENT: RESOLVE
10:12:40.802 -- Contacting [xx:xxx:21::3247:4670]:1194 via UDP
10:12:40.802 -- EVENT: WAIT
10:12:40.806 -- Connecting to [
xx.asuscomm.com]:1194 (xx:5580:21::3247:4670) via UDPv6
10:12:48.643 -- EVENT: DISCONNECTED
10:12:48.643 -- Tunnel bytes per CPU second: 0
10:12:48.643 -- ----- OpenVPN Stop -----
5 [nobind]
