Orbi Lbr20 - OpenDNS problems and other questions
MamaLbh
I am used to my previous setup - broadband internet and a pcWRT modem which made it easy to have different groups with different rules. So kids devices had moderate-restricted YouTube, went through OpenDNS, had scheduled calendars regulating access, etc where as IoT device had no rules or filters. Now we are in a rural area and our only option is cellular internet,
1) I have tried to get Orbi to use OpenDNS. In Advanced > Setup > Internet Setup I put in OpenDNS servers, click "Apply", restart router and computer, and it reverts to "Automatic from ISP"
How do I get OpenDns to stick?
2) High importance - where do I go to force Youtube to use moderate restricted mode and force safe search? I don't see a place in the GUI to do CNAMEs, maybe there's a way with command line?
3) Is there a way (using commands possibly) to set up the orbi with different groups (mac address based) with different rules? Or will it be easier just to hook up my pcWRT router to the Orbi via ethernet?
Some hints for you:
There was relatively old thread. Examples for R7800/R9000 but it should be the same for Orbi.
https://www.snbforums.com/threads/selective-parental-control-in-my-build-of-firmware.54815/
Maybe you should try to use DNSCryptProxy-2 with cleanbrowsing-family server:​
Blocks access to all adult, pornographic and explicit sites. It also blocks proxy and VPN domains that are used to bypass the filters. Mixed content sites (like Reddit) are also blocked. Google, Bing and Youtube are set to the Safe Mode. Warning: This server is incompatible with anonymization. By https://cleanbrowsing.org/
https://dnscrypt.info/public-servers/
I myself have to use DNSCryptProxy-2 cleanbrowsing-family server. Parental control. Works fine.
It is enough to change /etc/dnscrypt-proxy-2.toml file:
server_names = ['doh-cleanbrowsing-family']
Voxel.
Voxel, thank you for your reply.
I am very new to using telnet/SSH
How do I get to where I would type this in?
/opt/scripts/firewall-start.sh
#!/bin/sh
# Parental Control (forward DNS requests to OpenDNS Family DNS)
# Smartphone
iptables -t nat -I PREROUTING -i br0 -m mac --mac-source AA:BB:CC:DD:EE:FF -p udp --dport 53 -j DNAT --to 208.67.222.123
iptables -t nat -I PREROUTING -i br0 -m mac --mac-source AA:BB:CC:DD:EE:FF -p tcp --dport 53 -j DNAT --to 208.67.222.123
# Windows PC
iptables -t nat -I PREROUTING -i br0 -m mac --mac-source 11:22:33:44:55:66 -p udp --dport 53 -j DNAT --to 208.67.222.123
iptables -t nat -I PREROUTING -i br0 -m mac --mac-source 11:22:33:44:55:66 -p tcp --dport 53 -j DNAT --to 208.67.222.123
And, where do I go to make CNAME rules? Or, would this be something I could/should do in iptables?
Well... It is troublesome to explain all this...
You should understand all this. And to read my QuickStart.txt re: how-to.
Maybe it has a sense as a first step to setup DNSCryptProxy-2 with cleanbrowsing-family.
From SSH/Telnet:
nvram set dnscrypt2=1
nvram commit
mkdir -p /mnt/circle/overlay/etc
cp -p /etc/dnscrypt-proxy-2.toml /mnt/circle/overlay/etc
nano /mnt/circle/overlay/etc/dnscrypt-proxy-2.toml
Find the line in 'nano' editor
server_names = ['cloudflare', 'scaleway-fr', 'dnscrypt.eu-nl', 'dnscrypt.eu-dk']
and change it to
After that reboot your LBR.
Check that it is working after reboot, from SSH/Telnet:
cat /var/log/dnscrypt-proxy-2.log
If it is OK there should be something like
[2022-01-18 19:31:07] [NOTICE] dnscrypt-proxy 2.1.1
[2022-01-18 19:31:07] [NOTICE] Network connectivity detected
[2022-01-18 19:31:07] [NOTICE] Now listening to 127.0.0.1:64153 [UDP]
[2022-01-18 19:31:07] [NOTICE] Now listening to 127.0.0.1:64153 [TCP]
[2022-01-18 19:31:07] [NOTICE] Now listening to [::1]:64153 [UDP]
[2022-01-18 19:31:07] [NOTICE] Now listening to [::1]:64153 [TCP]
[2022-01-18 19:35:45] [NOTICE] Source [public-resolvers] loaded
[2022-01-18 19:35:46] [NOTICE] Source [relays] loaded
[2022-01-18 19:35:47] [NOTICE] Firefox workaround initialized
[2022-01-18 19:35:47] [NOTICE] Loading the set of blocking rules from [/etc/blacklist.txt]
[2022-01-18 19:35:47] [NOTICE] [doh-cleanbrowsing-family] OK (DoH) - rtt: 92ms
[2022-01-18 19:35:47] [NOTICE] Server with the lowest initial latency: doh-cleanbrowsing-family (rtt: 92ms)
[2022-01-18 19:35:47] [NOTICE] dnscrypt-proxy is ready - live servers: 1
Voxel.
