In the post below, @ryzhov_al showed there are pairings for CPU and RAM frequencies.
Does anyone know what the pairings are for an RT-AC88U ?
Not that I've seen. It appears to be tied to the CFE bootloader, which is now encrypted on the later routers.There's no way to circumvent that ?
When I ran the same test on the same router, the following results are less than half of what you showed. Why ?
Probably means you are not running at a valid clock rate. Check your bogomips. Incorrect overclocking attempts with downgrade the CPU clock.
I like the way you think, brb defaulting now. [emoji12]@john9527,
After a factory reset.
Maybe if I keep factory resetting, the speed will keep doubling.
Welcome To SNBForums
