Entware Pi-hole directly on the router? Yes!
You could try modifying /opt/bin/pihole by inserting debug info in those specific lines:
# In the case of alpine running in a container, the USER variable appears to be blank
# which prevents the next trap from working correctly. Set it by running whoami
if [[ -z ${USER} ]]; then
  USER=$(whoami)
fi
echo "USER = $USER"
echo "EUID = $EUID"
echo "UID = $UID"
echo "SHELL = $SHELL"
echo "PWD = $PWD"
echo "HOME = $HOME"
echo "PPID = $PPID"
# Check if the current user is not root and if the command
# requires root. If so, exit with an error message.
# Add an exception for the user "pihole" to allow the webserver running gravity
if [[ ( $EUID -ne 0 && ${USER} != "pihole" ) && -n "${need_root}" ]]; then
  echo -e "  ${CROSS} This Pi-hole command requires root privileges, try:"
  echo -e "      ${COL_GREEN}sudo pihole $*${COL_NC}"
  exit 1
fi
And retrying from the web UI and posting the output.
For me this outputs pihole user correctly.
Hmmm...I'm using a merlin-flashed AC86 as a wired switch on my network. amtm on it is up to date and I could easily add a drive for a swap/entware to run this script/package, since I haven't put any ad-blocking etc on my main router when it was commissioned...
do I need an experiment/source of stress and amusement? I may just...
Pi-hole released few patch releases so the package got updated once again: 2025.10.28-1
@heslo gravity update issue should be gone in this one
I have a spare AX58U and was thinking the same thing :-)
I might give it a go this weekend
I changed my mind when Asus released a firmware update for the AC86 - generally that indicates a vulnerability that needed patching, so I did...and I got some free time back, along with keeping peace in the house lol
I took that spare AX58U, set it up as an Access Point, disabled the radioes. Installed Entware, unbound-manager and Pi-hole.
I must admit, based on @jacklul opk and @bibikalka instructions - install went smoothly. Running happily now with a few test clients (thanks to DNS Director).
The one thing missing is how to have the clients showing up in the Pi-hole web interface. It shows just the router (in my case 192.168.1.1).
I recall there was a thread some time ago and how to get the clients to show up. I did a short search and couldnt find the details.
Might not be possible with DNS Director since the requests are being redirected and they will originate from the router (from Pi-hole point of view). I don't think setting up reverse query server in Pi-hole config will help here.
Unsure how exactly DNS Director works on the backend but if it could append MAC and IP to the query then Pi-hole will use that information.
For example, if you look at the stock install page on the wiki you will see I'm using "add-subnet" and "add-mac" dnsmasq variables to take advantage of this.
The one way I have tried which works is to disable “Advertise router's IP in addition to user-specified DNS” under LAN-DHCP Server.
Not sure the residual effects since the default is to advertise. With this setting off, I’m not sure DNS Director even comes into play…
I assume DNS Director is inheriting some of the DNS Filter code (or whatever that Asus feature was called).
I think it used iptables DNAT rules so that option shouldn't matter
Yeah, showing the correct IP can be tricky. I think the same issue is with the regular PiHole too if using DNSDirector. If I run PiHole on the same router which does DNSDirector then it knows the actual IP.
@jacklul - I also just upgraded to the latest package. Looks like there are some new variables in the config file? But it did ingest the old values correctly for the previous modifications.
Overall, very pleased with the package and my current on-the-router setup. Nightly router auto reboots also seamless so far with PiHole.
When running Pi-Hole on a Raspberry Pi, one typically has to configure the Pi-Hole Settings > DNS to use Conditional forwarding for the Pi-Hole to properly resolve the client names when the router is the DHCP server. One would input the main LAN subnet and any guest network subnets (Guest Network Pro, YazFi) into the Conditional Forwarding field (in the format indicated). Make sure to save any changes. I assume one would do the same with Pi-Hole running on the router and the Pi-Hole isn't configured to act as the DHCP server.
I think Pi-hole added some new options, doesn't affect the package.
-2 version because I made a mistake in -1 on the same day.
what is the command to update or remove the previous one?
"previous one" what?
Previous version after update? There is no need to do that as everything is packaged together and OPKG handles the updates.
I have a question, I was able to get this installed and working, But I was unable to get any of my devices to use it. Is there any trick to that?
Your LAN devices must use the device you installed Pi-hole on as DNS server, check your DHCP server configuration.
If you have only one router and that's the one you installed it on then it should work right away after following the installation guide for Asus routers.
Note that some devices override DHCP DNS with their own - both IOS and Android have an option to disable that somewhere in the networking settings.
That was my thought. I got it installed, logged in an now traffic was going to it. I had lan dns set to my rpi’s. But I removed that and left it blank. The router 192.168.50.1 was dns and I still had internet but no traffic to the pihole instance.
Before I did have unbound installed but it is the default settings and I changed the port to 5335 from 53535, any idea?
I will need a little more detail on your setup, did you change Pi-hole's port from 53 to 5335? That's wrong, no traffic will reach it.
Running "pihole debug", uploading it when asked and sending me the resulting URL might also help.
I did and it wouldnt let me change it back to 53. Said it was in use, could that have been because I have unbound installed before pihole?
