Could you please confirm/explain PoE to me - is this purely a convenience in situations when running power to the AP location is possible or there are some advantages to using this? Any speed limitations if I just connect it to power?
This is how I believe my network will look like
Cable -->
Mikrotik RB750GR3 (hex 3) as router -> TDB switch -> wiring in each room two runs for AP
ATT -->
Can I just use normal dumb switch in that role without PoE capability and
either
connect AP (unifi AC Pro) to both network and power
or
connect AP to network by installing a small PoE switch downstream of the main one.
Why am I asking this
- PoE capable switches seem to draw a lot of power and would be always on in the basement . I want 24 + ports of switching but only planning to have 2 APs max.
- I would love to run 'main' switch dump and only use PoE/increased power requirements where needed downstream of it. I would also love ability to 'turn off' the ports or shut down the devices automatically at schedule (with two very small kids right now, when we are asleep, there is no need for wifi in the house for APs to run and/or draw power). What would give me that capability? I see people trying running scripts on their Mikrotik devices
Please let me know if you have any questions
Cable -->
ATT -->
either
or
