Port Forwarding requires a reboot to work..
TomT
Hi
I've set port forwarding rules and they work fine.
But if I amend one to route traffic to a different device, I have to reboot the router to make it work..
It keeps sending the traffic to the OLD device until the reboot..
Any ideas ?
Try to restart firewall after you have apply your rules and test.
service restart_firewall
Thanks I will try that.
I'm not using hardware acceleration, not sure if that make a difference.
Just tried restarting the firewall rules and its not helped.
Doing iptables -t nat -L does show all the correct rules in place for Chain VSERVER
Any ideas before I reboot
Rebooted and its working fine.
Why do I have to reboot to change port forwarding rules ?
Maybe to clear out any caches used?
What router? If it's a MIPS based router, make sure the NAT loopback type is set to ASUS and not Merlin.
It's an rt68u
Should I just be able to change the settings via the GUI and they should work.. or is a reboot needed ?
It should work via the gui, and it shouldn't cause a reboot (It used to require a reboot if you had CTF enabled, but it was changed about a year ago).
But, I double checked....if you change the port forwards, in addition to
you also need to restart upnp
service restart_upnp
