I had ordered this for HP laptop, but it doesn't recognize the Mini-PCI Adapter 300Mbps by TP-LINK.
http://pic19.picturetrail.com/VOL1099/4465559/21344768/354191029.jpg
So I thought I remember seeing that DIR-655 uses Mini-PCI which it does. So I open it up and found this:
http://pic19.picturetrail.com/VOL1099/4465559/21344768/354191039.jpg
I found that the PC board is DIR-855 and DGL-4500 design.
http://pic19.picturetrail.com/VOL1099/4465559/21344768/354191047.jpg
Install with TP-LINK 300Mbps Mini-PCI WNPU
http://pic19.picturetrail.com/VOL1099/4465559/21344768/354191025.jpg
Working with Card installed (Close-up)
Now turns into DIR-825, (in theory NPU the same) this card doesn't have 3 connectors I only needed 2 connectors for the laptop. I've tested the signal on the laptop it's actual better it's coming in a -49dB instead of the prior which was -54dB the lower the number the better.
Note: I am running the latest beta firmware 1.21b11_beta02 with share point using 4-port USB2.0 hub to control 3 HP Color Deskjet with HP MFP on A3. Shown here:
http://pic19.picturetrail.com/VOL1099/4465559/21344768/353940799.jpg
