R7800 telnet issue... Any ideas?
Tom Brough
Hello all, like the title says, got a R7800 running the latest voxel firmware and kamoj v3 add on, saw the new v4 released so tried to update but I can't access telnet?? It's on in the debug menu but I keep getting this strange nonsense instead, anyone got any ideas?
Trying 192.168.1.1...
Connected to 192.168.1.1.
Escape character is '^]'.
SSH-2.0-dropbear_2018.76
�y>9MI����_��curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,kexguess2@matt.ucc.asn.aucdsa-sha2-nistp521,ssh-rsa=aes128-ctr,aes256-ctr,aes128-cbc,aes256-cbc,3des-ctr,3des-cbc=aes128-ctr,aes256-ctr,aes128-cbc,aes256-cbc,3des-ctr,3des-cbc$hmac-sha1-96,hmac-sha1,hmac-sha2-256$hmac-sha1-96,hmac-sha1,hmac-sha2-256zlib@openssh.com,nonezlib@openssh.com,none����l�E��
If you getting telnet issue, and unable to enable Telnet, Follow below few steps:
  • Open any browser and type 192.168.1.1/debug.htm in address bar
  • Enter username password
  • Next window displays, Select Enable telnet check box
  • Now keep enjoy and do not forget to turn off telnet afterwards.
Such message you've got just means that you are using port 22 for telnet. Port 22 is a standard port of SSH but not telnet. Telnet port is 23.
Try to use port 23. In putty or from Windows command line:
telnet 192.168.1.1 23
Voxel.
Something must have changed in an app update as I'm using a mobile app to access telnet, and it's a saved connection I've used loads in the past, but your right I just looked and it's port 22, changed it to 23 and it works again.
Thanks voxel.
