Impossible access to router via SSH
decedion
I have installed today the last Merlin firmware for RT-N66U.
I have activated the SSH access with SSH key:
But I can't access to router via SSH from Ubuntu Linux:
$ ssh -vv 192.168.1.1
OpenSSH_6.2p2 Ubuntu-6ubuntu0.1, OpenSSL 1.0.1e 11 Feb 2013
debug1: Reading configuration data /etc/ssh/ssh_config
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.1.1 [192.168.1.1] port 5622.
debug1: Connection established.
debug1: identity file /home/simon/.ssh/id_rsa type 1
debug1: Checking blacklist file /usr/share/ssh/blacklist.RSA-2048
debug1: Checking blacklist file /etc/ssh/blacklist.RSA-2048
debug1: identity file /home/simon/.ssh/id_rsa-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.2p2 Ubuntu-6ubuntu0.1
debug1: Remote protocol version 2.0, remote software version dropbear_2013.62
debug1: no match: dropbear_2013.62
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-sha1,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,kexguess2@matt.ucc.asn.au
debug2: kex_parse_kexinit: ecdsa-sha2-nistp521,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,3des-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes256-cbc,twofish256-cbc,twofish-cbc,twofish128-cbc
debug2: kex_parse_kexinit: hmac-sha1-96,hmac-sha1,hmac-md5
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA 1c:40:50:70:e9:4b:33:26:e3:e8:08:7b:c1:4c:7c:df
debug1: Host '[192.168.1.1]:5622' is known and matches the ECDSA host key.
debug1: Found key in /home/simon/.ssh/known_hosts:1
debug1: ssh_ecdsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/simon/.ssh/id_rsa (0x7f4e876fe390),
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/simon/.ssh/id_rsa
debug2: we sent a publickey packet, wait for reply
debug2: we did not send a packet, disable method
debug1: No more authentication methods to try.
Permission denied (publickey).
I've tried with my router user (ssh user@192.168.1.1) with same error.
In router syslog it shows:
Feb 19 18:23:54 dropbear[725]: Child connection from 192.168.1.2:33939
Feb 19 18:23:55 dropbear[725]: Login attempt for nonexistent user from 192.168.1.2:33939
Feb 19 18:23:55 dropbear[725]: Exit before auth: Exited normally
Why I can't access?
Regards.
Hola
Your key could be too large. Look at this thread
Ah yes it's in plaintext, have missed that bit:
You need to create user simon or check the spelling.
ssh service port "5622"
why did you change the service port?
default port for ssh is "22"
it is possible to use custom port
but then you specify what port to connect on when you attempt to connect
example
ssh admin@192.168.1.1:5922
admin doesn't work. I've tested with the "Router Login Name" and it doesn't work.
That makes sense, it looks for the admin's (root) credentials and/or authorized_keys in the /tmp/home/root/.ssh directory.
Have you created user simon?
Try
useradd simon
and set password with passwd simon
Hi, thelonelycoder
You mention in this post something I want to confirm: the user «admin» is in fact the root user by default during a ssh session (I'm running Merlin's fw 3.0.0.4.374.36_beta1 on a RT-N16), or, at least, it has root privileges, right or wrong?
I'm asking this because I'm struggling here with a strange issue: every time I try to change permissions to files stored in a formatted in ext2 usb HD (I access it from a Windows machine using WinScp) they revert to 777... I want to excluded as a reason for this the fact that in a session as «admin» user I don't own enough privileges to make that permission change (i.e., from 777 to 644 or 755) permanent...
Joao
In my case, this isn't so. My root user is the "Router Login Name"
Just wanted to clarify: The default user name is admin and this is the root user on the device. If you change the "Router Login Name" this new name is your root user.
Thanks for your fast answer
P.-S. Stil cannot figure out why I can't change permissions on my MemUp (which is formatted in ext3 and not ext2 as stated earlier)
cheers
João
