Reach device on guest network
ali232
Hello.
I have a device connected to Guest network #1 (192.168.101.0/24 subnet) which I’d like to reach from my PC (192.168.1.134). Is this possible? Maybe with some forwarding rules or with something else?
Thanks!
Yes its likely possible. But one may want to consider moving the Guest Network 1 client to their main WiFi network. Less hassle that way. You will likely have to setup a couple of iptables entries, or one can use YazFi and possibly it's custom scripting to accomplish it. There was a recent post on a similar issue, see this reply in that thread talking about using iptables:
https://www.snbforums.com/threads/security-for-iot-devices.80390/#post-784315
For YazFi see my response in another thread with general steps for using YazFi+custom scripts:
https://www.snbforums.com/threads/allowing-access-to-selected-network-devices.80405/#post-784521
More YazFi information:
https://www.snbforums.com/threads/yazfi-v4-x.70308/
https://github.com/jackyaz/YazFi
https://github.com/jackyaz/YazFi#custom-firewall-rules
