Recommended Wireless settings for high performance?
awaisuk
Hey,
I just got this router, and wanted to know if anyone knew the recommended wireless settings on this router, to maximize performance?
What kind of tweaks or settings did you change to achieve better performance?
Thanks.
This has been asked and answered many times. If you search you can find plenty of info.
Full correct!
The simple and straight forward guidance is: Rest to defaults (via WPS button) and change only what you really need (e.g. encryption, channel no., etc.)! :rolleyes:
In case of problems or slow speed: Search and read the forum!
There is no "one size fit's all" solution for the best WLAN performance. :eek:
With kind regards
Joe :cool:
