repeater (Asus RT-N10P) can't connect to AP (asus rt-ac68u). error "the parent-ap might be turned of
hiac
I ran into some trouble to set up repeater, and need your help :)
1) AP is: asus rt-ac68u merlin 380.65
2) I have two spare routers, which I try to use one of them to set up as repeater.
Asus RT-N10P
Dlink Dir-813
both face same issue
3) take Asus RT-N10P for example, I run it in repeater mode. During configuration I can scan and see AP (asus rt-ac68u), but when attempt to connect, it take about 2 minutes and eventually get a screen saying "the parent-ap might be turned off" (http://imgur.com/a/E9xrQ)
I read this post, it seems like last guy said it's working, but mine is still not working
http://vip.asus.com/forum/view.aspx?id=20130530153530861&board_id=11&model=RT-N12&page=1
I wonder if I need to configure anything at AP or at repeater?
Thank you very much!
Asus RT-N10P
Dlink Dir-813
Hello,
have you managed to solve it out? I am trying to use a asus rt-ac1200g+ as a "master" and an asus rt-n12+ as a repeater.
i got the same errors as you with the repeater. :(
