RT-AC68U and Black List options
Noki388
Looking for some assistance please,
I have an Asus RT-AC68U router and have Dahua NVR with cameras. The NVR is connect via ethernet to the router and cameras are connected to the NVR so are on a "subnet".
I want to block all outgoing connection from the NVR with the exception of port 2195. The reason for this is that I want it to send notifications to my iphone. Reading this and other forums, I understand that Apple requires port 2195 (and 2197 for newer device) open for its Apple Push Notification.
I am wanting advice on how to set it up. It seems to have the following options under Firewall -> Network Services Filter:
- Source IP: I presume this is the IP address of the NVR
- Port range: ?
- Destination IP: I presume I leave this blank
- Port range: ?
- Protocol: I presume TCP. Do I also need UDP?
With the port range, do I choose the port range for the Destination IP as I presume this is the Apple Push Notification? Or is it the Source IP port range?
As I want to block all ports except 2195, what is the best way to do this? Do I need to setup 2 separate options
eg first with 1:2194 and second with 2196:65535
Been doing some reading and came up with a possible solution but wanted to get some opinions in regards whether it is a safe and suitable option.
Essentially I want to block all outgoing connections from my Dahua NVR with the exception of port 2195 for iOS notifications.
Under firewall -> Network services filter -> Blacklist
Source IP - xxx.x.xxx.x
Port range -
Destination IP -
Port range - 1:2194
TCP
Port range -
Destination IP -
Port range - 2196:65535
TCP
I have only done it for TCP protocol, do I need to also do it for UDP protocol?
It seems to work as on the Connections tab, I see that the IP address is blocked whereas previously it was connecting to an outside IP.
I only have the offical Asus firmware but noticed that on the Merlin firmware, there seems to be options with both jffs scripts and Skynet. With what I have done, is it still doing the same thing.
