RT-AC68U - Change hostnames of clients
ca509
I've setup my AC68U routers which are working fine, just one point annoys me:
The names of the Android clients and some printers in the client list. I have given them a fixed ip via dhcp assignment.
For example the phones show up as android-xxxx-xxx or so in the list.
So is there a way to change to hostname or the name that is shown in the client list for those phones, so lets say instead of android-xxxx-xxx it states MyNexus or so?
Thanks!
If you are using Merlin FW (3.0.0.4.374.35_n) you can add hostname to your fixed dhcp list. From that point onward your clients list will display the hostname you added in this fixed list.
Thanks!
Shure you shuld reneme hostname in "Android"
Change Hostname (google play)
