RT-AC68U no more control
soleillune
Something strange happenned to my router, here is a view of the web UI:
There is no more menu on the left. Did a rebout or a reset and it didn't came back.
Please help!
EDIT:
forget this post, i found the problem
Disable ESET or other firewall/antivirus software or use Safe Mode with Network support (F8 at OS boot) and try it.
Do you have Sonos Wirless Speakers on the same network as your router? :rolleyes:
I had similar issues with the N68U - do a small search on the forum you you will find my postings about it... :D
With kind regards
Joe :cool:
