RT-AC86U Optimum VPN settings for gaming
GK59
Can someone please help with how I can set options for gaming under VPN client, things like Compression algos etc.I'd be very grateful.
RMerlin
Asuswrt-Merlin dev
You cannot customize those, the settings to use are dictated by the server to which you connect.
GK59
Hi Merlin, I might have misspoke, I'm referring to "Compression" under advanced options, things of that nature.
RMerlin
Asuswrt-Merlin dev
That's one of those settings that is dictated by the server. If the server is configured to use compression, then you have no choice but to also enable compression in the client. The server will have the final say as to most of these settings (cipher, compression, hmac, etc...).
Zonkd
Is this regarding the OpenVPN protocol only? Any specific reason you wish to do gaming through a VPN network? It’s more likely to cause slowdowns. Better to connect to game servers directly.
Are you trying to connect your router to a friends VPN server for virtual LAN gaming? Or are you using a paid commercial VPN service? If you’re using a commercial VPN provider then their website should let you download a client config file with the settings required to connect to their server. Import it, or manually copy in the certs and keys.
As someone who’s read the openvpn man pages top to bottom with experience managing their own PKI manually I can tell you it’s complicated and some options while named similarly are deprecated or impact security. It’s best to just use the settings they tell you. They should hopefully know what they’re doing.
Once again, I think you’re better off not gaming through a VPN connection. Let us know how you go.
martinr
Part of the Furniture
A welcome reminder of how easy setting up OpenVPN Server has been made for us: a couple of clicks, import the .ovpn file and you’re done. No knowledge of PKI required.
Zonkd
A dangerous assumption - a little education never hurts
Haha I said that because I didn’t want to start another debate about whether a particular VPN company is properly secure or worth the money. All I can say confidently is morons use free VPNs and lifetime VPN subscriptions seem unsustainable without making compromises.
